Need Help with Fuel Filler Neck Trunk Seal
1969VADart
Fredericksburg, VA
We replaced the entire trunk pan in my 69 Dart. I bought the AMD trunk pan that is for all A-bodies for 67-76. However, the new fuel filler neck trunk seal (the big rubber piece that sits in the trunk floor where the neck goes through the floor) that I bought, does not appear to be big/wide enough to cover the hole in the new trunk pan. I checked out an old trunk pan out of a 69 Dart that I had and the hole in the trunk pan is definitely narrower. The new rubber seal looks made for that hole but not the one cut in the AMD trunk pan. Anyone have pictures of their trunk seal after replacing the trunk pan in their Dart? I want to see if I should be looking for a different part. Thanks.
The AMD replacement floor uses the 70 up Gasket/Seal.
If you do not care about accuracy then just get a 70 up Seal.
I you do then some more fabrication and welding is going to be required.
Thanks for the input. Since it will be covered up by the trunk mat anyway, I will just probably opt for the later seal. Car is not all stock anyway.
