Need Help with Parts ID
KevinB
Austin
Got these off my donor 66 Dart, a lot of misc junk was in the car. Some of these items may be from a lawnmower for all I know. Help!
First up:
Water pumps. I believe the orange one to be original, since the 273 it came with is orange, but I can't ID the other one
Next up is AC components I think. This car has factory AC but the engine bay is more or less cleaned out of that stuff.
Now is the really random stuff. The first pic is a pair of cigarette lighters with screws in the base as if to mount to a dash or something. I can't find anything about them. The second photo is some sort of turnbuckle device with a large tab welded on.
The others I have no clue about.
Next is some sheet metal pieces
top pic in post # 3 is the rear splash shield ...um looks like passengers side
bottom pic is the front splash shield that goes right behind the headlight bucket.
in post number 4 the
#1 it looks to be an aftermarket add-on cigarette lighter just like I use for additional power outlets, got em at a boat/marine place for a few bucks each.
#2 and #3 no clue at all.
#4 pic is the battery tray support brackets
#5 makes me want to say alternator bracket but neither of my 66's look similar (/6 and a 273) but neither one of them has air either. (yet)
pic # 6 is the master cylinder to brake pedal pushrod, and "no" it does not usually come with the new master cylinder and "Yes" it will fit in a dual(later model) master cylinder. it looks to be stuck in the master cylinder bore. it is held in "usually" by a tigh fitting rubber ring or cap on the end of the rod and a bear to get out sometimes.
#7 not a clue my /6's were rod operated for the carb and kickdown rod. the v8 had a cable to carb and a rod to kickdown. but it looked nothing line the picture
First up:
Orange is early up to 70? Right one is later pump, requires different timing cover and balancer, or at least re-marked for timing marks
AC receiver / dryer, one with tubing I believe is just a sort of muffler for the AC. Reduces compressor pulses
I could be wrong,
I don't believe no 2 is Mopar, turnbuckle. Might have been an aftermarket engine torque strap
I don't believe no 5 is a Mopar part, the black cast bracket
No 6 is master cylinder pushrod..........still imbedded in the master piston. Who knows? what year/ model from that LOL
Thanks All! That helps sort some of this crap out. I'm sure I'll have more to ID soon, this is just the top of the iceberg of what was in this car lol
#10 are battery tray brackets
#11 looks to be an alternator bracket. Possibly from a slant 6. But I could be wrong. Eric L
