Need some head, help
mopardrt
Detroit
Ok, so 7 years ago when I was much, much less experienced I built my 360 and I used 3769973 heads which are 318 heads with 1.78 intake and 1.50 exhaust. Anyways I had the heads decked, 3 angle valve job, better springs we did a lot to the heads. All of that brings me to this, I have the chance to buy a set of J heads casting number 3418915-H with intake of 1.88 and exhaust of 1.60. I am pretty sure I can grab them for like 200.00$ would I actually notice a difference and or is there a real reason I should switch over?
What do you do with your car? If it is a 100% street car, then no, I don't think you would ever feel the difference.
Yup just a cruiser, my dad just said the same thing on the phone, said I will never notice it.
Let's see, a 360 cubic inch motor, heads designed for it have 165cc ports and flow in the 215 cfm range...you have unported heads designed for a shorter stroke motor that's 42 inches smaller with 124cc runners and flow 170 cfm.
While I agree with most about you might not being up to a head swap and its just a cruiser in which the lil heads will give better mileage...here would be a lot of power gained when you consider the 45 cfm gain by swapping to a 360 designed head.
So then you think even the bigger valves and ports would trump the lower compression of the 360 heads. Even for a 100% street car?
Well good question, the added air will fill more and thwt can add to squeeze...but yes I know the 360 head could be 72cc compared to the 68 cc 318 head. I think in a case like that, milling from 72 to 68 cc's wouldn't be too much hassle. But that's jmo and like mentioned, he might not want to deal with a head swap.
Is that all the difference is? Like from 68 to 72 CCs? I thought it was more. In that case, I gotta retract and agree with you. lol
I agree there might be something there - but honestly - for a cruiser that' salready cruising - the purchase, gaskets, and misc stuff to swap them - the gain wouldn't be that noticable. It's not like it's got a cam that's getting anywhere near peak flow anyway so given the improvements in terms of valve job and whatever they did (guessing again it's not max prted but more of a "cleaned up" deal) the two would be comparable in the lift ranges of the camshaft. There might be a little more flow, but you have the larger chambers. So you incur more cost to mill...
As I said - it just ain't worth it.
Personally, I couldn't even consider running the "small port" 318 heads on a 360, unless they were highly massaged 302 castings. Seriously.....you're running heads that are smaller than stock?! Good gawd, your car may be a cruiser, but do you have any plans on revving past 3500? LOL No, I say go "J"....no question.
Another thing to remember is.....you're going to have to change your intake manifold to one that is designed for the taller intake ports of the 340/360 head.
Yeah the heads have been ported and polished, the motor is all ripped apart right now getting a new cam and swapping intakes, the heads would just need to be unbolted, I have yet to hear back from the seller with the J heads I originally planned to swap out to magnum heads but now we cant find the lifters or pushrods for the magnum set up so it would cost quite a lot of money for all that, not to mention having to purchase and intake for the magnum heads, I would be approaching like 500.00 by the end of a magnum swap.
If it's torn apart, makes more sense to me. Do these J heads need any work to be installed?
I don't think so, I have not looked at them, I would just hot tank them, and swap over my set up from my current heads
Dude save your money all those old parts are too old technology as well as cost too much to build. A set of aftermarket aluminum heads is much cheaper and cost efficient now days.
