Need some help from my head machining buddies
Mopar Racers Forum
  1. PRH
    PRH Well-Known Member
    2,673
    4088
    Dec 14, 2018
    So. Burlington, Vt
    Local Time:
    6:13 PM
    John, the bits are usually in the $30-45 range, depending on what it is.
    Buy the bit with the profile you want, and bring it with your heads to the shop...... and say, “use this”.
    • Agree Agree x 3
    • Like Like x 2
    • replicaracer43
      replicaracer43 Grumpy Old Man
      4,490
      3499
      Oct 10, 2008
      Local Time:
      5:13 PM
      Goodson and Silver Seal both sell the cutters with the multiple angles, and there are a BUNCH of different ones to choose from
    • pittsburghracer
      pittsburghracer FABO Gold Member FABO Gold Member
      4,151
      7565
      Apr 20, 2016
      Freeport, PA.
      Local Time:
      6:13 PM
      Ya I checked out my Goodson book last night and again today.
    • replicaracer43
      4,490
      3499
      Oct 10, 2008
      Local Time:
      5:13 PM
      Go online and request a silver seal catalog, you can thank me later!
      • Thanks! Thanks! x 1
      • PRH
        2,673
        4088
        Dec 14, 2018
        So. Burlington, Vt
        Local Time:
        6:13 PM
        You would just need to verify with the shop you use that they do in fact have the tooling to use that style of cutter.
        That type of tooling is fairly universal these days....... but not “everyone” has it.
        • Like Like x 1
        • PRH
          2,673
          4088
          Dec 14, 2018
          So. Burlington, Vt
          Local Time:
          6:13 PM
          One of my customers used to have a speed shop/machine shop.
          He sold it off probably 12-15 years ago.
          He kept a small group of his circle track customers that he still does motors for, and he brings me the heads for the guide and seat work for those jobs.
          There is often a little discussion about what angles he wants, and what chamber or bowl cuts that may be needed, etc.
          If you’re looking to have something done a certain way, don’t assume the guy at the machine shop is a mind reader....... have the talk and discuss it.
          • Agree Agree x 1
          • skrews
            skrews Well-Known Member
            1,578
            1125
            Jul 20, 2012
            Washington state
            Local Time:
            3:13 PM
          • pittsburghracer
            4,151
            7565
            Apr 20, 2016
            Freeport, PA.
            Local Time:
            6:13 PM
            Signed up for a catalog. Thanks.
            • Like Like x 1
            • pittsburghracer
              4,151
              7565
              Apr 20, 2016
              Freeport, PA.
              Local Time:
              6:13 PM
              9F79C049-9A02-49FD-AC2F-8D1FA3A77330.png I would love to play around with that number 2
            • yellow rose
              yellow rose Overnight Sensation FABO Gold Member
              25,670
              21778
              Jun 19, 2015
              Under The Gun
              Local Time:
              3:13 PM
              Look at the 50 degree cutters while your looking around.
              • Like Like x 1
              • pittsburghracer
                4,151
                7565
                Apr 20, 2016
                Freeport, PA.
                Local Time:
                6:13 PM
                Having so many sets of Edelbrock and now a set of Speedmaster heads laying around I like the ability to interchange parts from head to head. Once I start going away from “standard” valve angles I lose that. Standard angles have been pretty good to me over the years.
              • PRH
                2,673
                4088
                Dec 14, 2018
                So. Burlington, Vt
                Local Time:
                6:13 PM
                Often times with those cutters that have multiple angles above the seat...... there isn’t enough radial clearance in the chamber before the cutter OD starts carving out the chamber wall.
                Sometimes that’s a problem...... sometimes it’s not.
                Also, many heads will require sinking the valve a fair amount to be able to utilize all the angles.
                Sometimes that causes issues on the top side of the head with regards to tip heights and installed heights.
                It can turn into a “be careful what you wish for” scenario.
                It’s playing with that type of thing where having access to your own machine really comes in handy.
                • Agree Agree x 1
                • pittsburghracer
                  4,151
                  7565
                  Apr 20, 2016
                  Freeport, PA.
                  Local Time:
                  6:13 PM
                  Don’t ask me why but the piss poor small block Edelbrock type head chamber likes to be sunk a little to slide a 15 degree top cut on it. It’s worth at least 6-8 cfm. My thinking is it raises the airflow up off the chamber floor and avoids crashing into the almost vertical back wall.
                • skrews
                  1,578
                  1125
                  Jul 20, 2012
                  Washington state
                  Local Time:
                  3:13 PM
                  The deshrouding cutter I commonly use has a °15 bottom angle to it. My "go to" performance intake profile is °35 x .080" top °45 x .040" seat °65 x .100" bottom.
                  • Like Like x 2
                  • Agree Agree x 1
                  • pittsburghracer
                    4,151
                    7565
                    Apr 20, 2016
                    Freeport, PA.
                    Local Time:
                    6:13 PM
                    First off thanks for suggesting Silver Seal. I requested a book as suggested and received it yesterday, great service. I called Goodson today to see if tooling was still available and undateable and he said yes. Looks like for a few hundred dollars in tooling and 175-200.00 for a phase inverter I cut be grinding seats. I told my buddy 2000.00 for the machine plus new tooling was more than I wanted to spend so he said he could drop it to 1500.00 but since he is going south it won’t be available till around May which is fine with me. That gives me more time to think things over. I sold a head and block cutter for him to another friend of ours for 2500.00.
                    • Like Like x 1
                    • moper
                      moper FABO Gold Member FABO Gold Member
                      15,771
                      1886
                      Dec 27, 2004
                      eastern CT
                      Local Time:
                      11:13 PM
                      I just sold my Peterson TCM-25 with the better fixture and all tooling and manuals for it. It’s a great machine and you should be able to cut whatever you want. Only real issue is the spindle rpms are preset (gear selection) not fully adjustable like more modern stuff. Also the table floats vs the head but on most old stuff that’s fine.
                      IMO $2k is a lot if it’s been dormant all this time.
