Need to remove combustion chamber deposits
redneckmba
Active Member
South Louisiana
I did a compression test yesterday and I got some numbers that were quite high on some cylinders. The two cylinders with lower numbers were in line with what is expected. I believe I have deposits built-up in the combustion chambers.
Anyone have a recommended product and/or procedure to remove the deposits???
Carl
seafoam is good for this put motor on high idell and pur slowly in the carb.and put a can in the feul tank gooooood stuff..........Artie can be found at any auto parts store
