johnnydemon
Hello All,
I have put about 150 miles on my new build, 1972 Dart Demon. During this time, I have changed the mechanical fuel pump three times due to fuel bowl becoming empty. Yesterday, I drove about 12 miles to a car show and while parking, again had 0 fuel pressure and no fuel in the fuel bowl. I let the car sit for three hours, primed the carb and the motor started right up. I drove the same distance back home and the same thing happened upon entering my garage.
I believe that I should now rule out the fuel pump.
Fuel filter near the fuel tank and another near the carb.
6 lbs of fuel pressure which holds steady until this situation occurs.
Metal 3/8" fuel line from the tank to about 12" from pump. 3/8" braided line from line to pump and then from pump to carb. The braided line DOES run from the pump through the alternator bracket and up to carb.
Lower radiator hose is about 3/6" away from fuel pump which I am speculating as a possible issue here.
The motor is a 408, 10.8:1 compression, roller cam, etc.
Any help or suggestions would be appreciated.
John
John
