New Hemi tranny on a 2000 360 Magnum Create Motor?
360-75Duster
NY
Has anyone tried to put a Hemi tranny on a 2000 360 Magnum Create Motor in a 1975? Just trying to see if there is anyone that has tried this. I have a semi-pro-street 1975 Duster with a year 2000 360/380 Magnum Create Motor connected via a 727 small block transmission with some work and 4:56 8 3/4 rear gears. It's great but I'd like to go longer distances than I can with the gears I have in the rear. So I've heard the new Hemi's come with 6 speed transmissions and thought, let's see if someone has tried to do this then I'll give it a shot if it is feasible.
Thanks,
Steve
360-75Duster
Haven't tried it but I can tell you it's too physically big to fit in an A-body transmission tunnel so you'll be doing body work and modifying the crossmember on the car to make it fit.
