NHRA TV Video Interview on My Stock Eliminator Wagon
I'd help you out in a heartbeat, Brother, and this phone even came with Facebook installed in it when I bought it! I removed it, and Barbs not here, so I can't use hers. I wish I could be more help heck I'd love to see the station wagon anyhow! Sorry
You'll have to scroll down a little to find it, they're arranged by date.
John, what does a competitive 318 stocker motor cost to build?
It depends on how much you can do yourself.
If you have to pay a top engine builder = $10,000 + and you
supply all the core parts.
The Wagon is a small Valve (1.78/1.50) with a .375 lift camshaft
and not much compression to work with.
To be competitive you better find a way to make this 145 HP engine
produce 400HP plus in this heavy Wagon!
So is the lift restricted by the rules?
Stock Lift as produced
Basically I take the fastest rate of lift roller camshaft I
can fine and reproduce and reduce it to stock lift.
Pretty much square when finished. Then take a tool steel
or ceramic bottom lifter with insane Valve Spring Pressure
(200++) on the seat and never let it idle at all.
I see. So duration rules are unlimited and of course sounds like rollers are legal too. Pretty slick, John!
Thanks John. It's cheaper than I thought it would be.
Roller Rockers are now legal but I do not use them.
I can play with the pads on the cast adjustable rockers to
play with the rate of lift to get a bit of more lift earlier.
No roller lifters = they would be cheaper than the billet cams
and tool steel coated solids that are legal and most guys uses.
I use a hydraulic lifter with a ceramic puck (think space shuttle)
on the bottom and travel shimmed down to about .010 to cushion the
hard but fragile material!
It could be much cheaper if you pick a class that does not have many
fast cars in it and you do not need to be a top Alpha Dog!
I finished in the top 3 in the Division the first few years when I only had
about $6,000 (1995 Dollars) in my entire Demon. I had a small pickup
and an open trailer with a crew consisting of a 5 year old and a 12 year old
(Single Parent). I had the time of my life doing it!
My friend Mark races in Stock Eliminator an Escort that he probably has less than
$3,000. invested but a lot of time and effort and does well.
Another friend Gary just won last week a Stock/Superstock Combo in Tucson with a
Cavalier that he pulls on an open trailer with a small truck.
But I made a lot of enemies and I could not stand to see them beat me
Heads Up in class = So I opened up my mind and wallet for the next 30
years. It takes a lot of both of them!
I thought you said up there ^^^ that you use a roller style cam. Do you use flat lifters on a roller lobe?
Gosh, I bet that was fun!
Yes
But I do not recommend it to anyone as
the required spring pressure is enormous to
try to get them to comply and not bounce
and be a total killer on everything!
Yes
Oh I'm sure, but quite obviously you found a way to make it work at least for what you're doing.
