Shainesboostin
Anyone have a good option on a manual valve body? Sounds easier. And I would like it anyways.
You must have had better luck then I
I ran thier throttle cable for a while and quality failed me rather quickly
The stud that mounted to the carb stripped it's threads, the cable actually cut a groove in the ferrule it ran through and eventually the cable ended up fraying and breaking
Every cable setup I have ever seen will cut into the ferrule's if it comes out off center.
Summit Racing has some.
I wont argue against that
but I will argue that it shouldn't happen in a time span of less then 2000 miles
I took it as a sign they used a metal on the ferule that was too soft
(this was on the firewall side, where the cable enters the car and gets attached to the pedal...pretty straight shot)
But can I run it with a column shifter, also, when running a manual valve body, what is done with the kickdown lever?
Not sure why you think a RPMVB can't be used with a column shift. The PRN123 pattern is ideal for it .You are probably right, I have had mine on for a bit over a month with no sign of wear whatsoever but I lubed it really well with graphite powder also before it went on.
You can run a manual valve body with a column shift, just not a reverse manual.
With the manual VB all of the TP linkage can go away. (just leave the lever off if the VB comes with the rod for it. (most don't as far as I know)
Easy to do in car. Doesn't take much longer to do than a filter change. Get the car on jack stands with the rear wheels . You will have to rotate the driveshaft to disengage the parking pawl. Might be a good time to change your selector shaft seal while you have the vb out.So with a manual VB, no kickdown lever is even needed? Also, can you guys make a recomendation on where to buy, I see them everywhere! Some told me the cheetah brand? Can I do this with them trans in the car?
So mine column would read as followsNot sure why you think a RPMVB can't be used with a column shift. The PRN123 pattern is ideal for it .
I've never upgraded the servo and haven't had a problem in 20 years of running RPMVBs. Probably a good idea to upgrade though and not very expensive. The factory retainer is kinda wimpy I think. No need to pull trans to change it. http://www.turboaction.com/17156.pdfSo mine column would read as follows
PRND21 but would function as
PRN12D
Looks like you.gotta do a low reverse servo upgrade as well. Pulling trans...yay
I think you will want a ratchet shifter soon.
Baloney! Their no more to set up than a throttle cableMay look for a manual valve body instead. Keep hearing the cables are a nightmare.
