Ok parked my car for about 8 month, went out to start and it had no spark.
1964 Valiant 318 with mopar electronic ignition and electronic voltage regulator.
I have checked the ignition switch, it has the correct voltage in the start and run position, I have ohm and volt check the coil, checked all grounds including the ECU, Ohmed and volt checked the distributor and also the ballast resistor, checked and double checked the pick up/reluctor gap .008 non magnetic feeler gauge. I have even pulled the wire harness apart to check for bad wire.
Also when the key is in the on position the ballast resistor starts to smoke.
The car ran fine 8 month ago, and now I got gremlins. I know I am just not seeing something, and I am sure it is something simple....
any help would be appreciated
:banghead:
:banghead:
