OD trans
Steve welder
New York
Has anyone had any experience with the OD 833 4 speed that Brewers sells?
Im considering it as im looking into a OD unit for my car
Its currently has a 4 speed 355sure gripe and 15inch rims and its just not enjoyable to drive at highway speeds
Thanks for all thoughts and replies
If the transmission is a stock rebuild, then the missing thing is the company’s reputation that your looking for. Which is a good reputation as far as I know.
My friend and member here @smokindust and another friend of ours run the regular 4spd units that have been modified with what they call “Faceplated gears.” They love there stuff and have been running them for years. Though the modified parts are more so for racing, they do street drive them.
Steve, We installed a similar trans from Passon Performance in a 73 'Cuda.
451 Big block with 3.73 rear. Drove it on the Hot Rod power tour. It was a world of difference that made cruzin comfortable.
We looked at 5 speeds and 6 speeds. The conclusion was the 4 speed OD that was less then half the cost was our best option, and has served the owner well in the past 15 years the car has been on the road.
The Chrysler OD - A-833 is a gear change on the what is normally 3rd gear and changed to the overdriven gear. 4th becomes 3rd gear.
yes
So 3rd gear is 1:1?
In a Chrysler (or Ford) overdriven 4 speed, what becomes 3rd gear was the old 4th. All they did was turn the shift lever on the trans upside down so that the GEARBOX shifts 1-2-4-3 as YOU shift 1-2-3-4 and of course "regeared" the original 3rd gear
Fourth or "high" gear in a normal, traditional 3 or 4 speed is always a straight through shaft coupling and cannot be changed. You could throw away the cluster gear and 4th gear would still work
You will have to change the bell housing and probably the fork also. you will have a better highway experience, but will suffer a little around town as the gear ratios are pretty spread apart which makes the upshifting and down shifting more difficult.
the input shaft retainer is different. there are gear ratio breakdowns on here about rpm/power bands when doing this swap. plus' and minus' ie no free lunch. @AJ/FormS has a slight grasp on the in/outs:poke:
Owning a Duster with a 3spd manual, which also has the low first gear, it is just a matter of holding the gear change a few hundred rpm. It’s a little weird when your used to a normal 4spd. But NOT! A big deal at all as others would have you believe or mathematically work out.
I agree.
I have owned my Duster for 20+ years in total and it has always had an A833OD in it. It was more the luck of the draw rather than planning as it was what I found to get it on the road. The car was my daily from 1993 to 1999 with that trans and a low comp 360 with an Isky Mega 270 cam. And it was fine.
Better splits would be good, but the A833OD works. Drove it all over town this weekend for a club garage tour and never once did I think "dang, these gear ratios suck!".
What are the gear ratios in 3 speeds?
I have heard they are the same as the OD unit.
The one issue that occasionally bothers me is that it seems there are more 2-3 (cross-gate) shifts than a traditional 4 speed.
If the ratios are the same, those shifts would be on the same side driving a 3 speed trans.
Ratios? Hummm.
I’m not sure. I have seen them listed around.
The gate shifting doesn’t bother me any.
A230 ratios
For slant sixes and 318
1st 3.08
2nd 1.7
3rd 1.0
R 2.9
for 340 and 400s
1st 2.55
2nd 1.49
3rd 1
R 3.34
I've got access to a close ratio three speed out of a 340 Demon with the factory Hurst floor shifter. I'm going to score it just because I don't want to let it get away. I'm thinking that it will be fun when it comes time to swap to a V8 in the SWB D150 with the existing 3.90 rear. But being it's a truck, I'll probably rebuild the Dakota 5 speed NV3500 I got lying around.
Thanks Garrett!
My 3spd manual was in a 318 Duster. Moon roof, fold down rear seat, 3.21’s spinning the pair. Fun car!
When ever I would get on it messing around with the old buddies, they could not believe it was a 318. Let it scream and slam it into the next gear letting the pedal up unassisted.
There was supposedly an a230 "challenger ratio" transmission with a 2.25 1st and a 1,37 2nd. I've chocked it up to another internet legend unless it was possibly an over the counter item for the kit car oval track program. I think it would make a helluva 1/8 mile transmission with a light car and very low gears if you weren't being forced to slam the shifter and the rearward clutching sleeve toward reverse when making the 1-2 shift. If something made that rear clutch fork go too far by accident under the force of a full on power shift, it wouldn’t go well.
Oh you guys ...............
Over and over I tell you I'm a streeter.
And in real-world experience, Second-gear is where it's at; on account of with a 3.09 low, First gear is just a tire burner.
If you install this A833od box in your car with 3.55s, that would give you a miserable Second gear of 1.67 x 3.55= 5.93 which is similar to
1.40 x4.10s= 5.74 THIRD gear with a Standard A833. How often do you skip-shift your current combo?
Meanwhile the 3.09 x 3.55= a tire-frying 10.97 Starter gear, which would also be like 4.10s with a Regular A833,( 10.91) in First gear. So it's like shifting a Regular A833 with 4.10s, straight from First to Third, skipping Second. WHERE is the performance in that? A good Second road-gear to have is in the range of 6.80 to 7.20, depending on your combo
Look here;
the od box with 3.55s has roadgears of;
10.97------5.93-----3.55-----2.59 compared to;
10.91-7.87-5.74-4.10 -------- the Regular box with 4.10s.
You see any 6.80s to 7.20s in here?
The splits are; .540-.599-.73 (od box)
versus .718-.728-.719 Standard A833; You know that .718 x .728 =.523 which is only a tiny bit different than .540;
SO IT'S ALMOST EXACTLY LIKE SKIPPING SECOND-gear.
Again; How often do you skip-shift your current combo?
But that's ok for guys who already own one, cuz well cuz.
But if a newbe doesn't yet have a trans, or does have an od box but doesn't have the whole nine yards, there is no way I would ever recommend this trans for anything but; a lo-po, small-cam or wide LSA cam, cruiser.
Been there/done that/ got the broken parts to prove it/ ain't ever going back.
but hey, I at least tell you; "This is my opinion."
Whereas "others" like to kick the chair out from under me.
From the First post;
I totally get that 3.55s are not enjoyable on the hiway.
With my very first combo, I ran a 25.6" tall tire, and 65mph was a tic over 3000. My first move was to install 28" tires for a new rpm of 65=2770. Then I slowed down to 60=2560 which was still uncomfortable.
So in went the 3.23s, and 60=2330 Ok now we're getting somewhere. But that 2.66 x3.23=8.89 starter gear was none too performance oriented, but worse is that Second gear was now a miserable 6.17, which made 60= 4440, so there was no performance in that.
Ok so then, like you, I thought, I'll give that od box a chance. Of course I knew about the split. And I knew I never wanted to see another 6.17 Second-gear, so in went some 4.10s. Second was now 1.67 x 4.10=6.85 which was almost perfect; 60 in Second was now a tic under 5000, and in od 65=2330 ..... YABUT, First-gear was a staggering 12.67
So I got the idea to install a GVod and split those wide buggers. Of course with a double overdrive, I could run any rear gear in my collection. So I ran some 4.30s. Those 28s had worn out long ago, and by now I was on 27s. So Second-gear was a whopping 7.18, and 60=5370 now we're talking! In Dod, 65mph was 1990rpm, now we're talking! Of course the Starter-gear was 3.09 x 4.30=13.29 ..... but I hit the splitter right out the gate, and she shifted at just the right time into First-over for a Sweet ratio of 10.36, Shazzam! The bonus was that First gear of 13.29 is a great ratio to idle around the parking lot at 550rpm=3.3 mph.....
This combo gave me Seven usable gears to cover every situation. But in the end, having to split gears almost ALL the time just got to be a PITA. And I kept breaking that stinking tiny overdrive gear...... which usually tore up the rest of the box.
So enough was enough; I pulled the last good box out, and in went a Commando box with the GVod behind it. This box has the 3.09 starter and the rest is just like the Regular A833. So I started with 3.23s. This gave me 60=4630 in Second, but 60=5840 in First-over, Shazzam! And 65mph in Fourth was 2620, but in od was 2040. And the Starter gear was a perfect for my combo of 9.98. So I ran this for a very long time.
So I know what yur up against. And so I highly recommend the Commando box, with a rear gear change. The Ratios are
3.09-1.92-1.40-1.00. You can run this with 3.23s or less. In fact with your current combo I'm guessing is the 2.66 Regular box and 3.55s, your road gears are;
9.44-6.82-4.93-3.55
if yur happy with that 9.44 starter, then you can even run a 2.94 rear with the Commando... which would give you the following roadgears;
9.08-5.64-4.12-2.94, and 65=2380 with 27" tires.
(or 9.98-6.20-4.52-3.23, and 65=2610 with 3.23s and 27s)
What's also nice about the Commando/2.94 combo is that Second-gear is good to about 80 mph@5650rpm for passing ......... starting at 4000=57mph. I really liked this with one cam I had. Peak torque to peak power in the blink of an eye.
But I gotta tell ya, Third gear (4.12ratio) kindof sucks at WOT, mostly because your car is already moving at 80ish mph when you get into it. But honestly, for that same reason, and for a streeter, it almost doesn't matter.
So in this sense, the Commando is like a poor-man's overdrive, but sortof better, cuz it works with any rear gear you chose, up to say 3.91s ( starter of 12.08), or the perfect Second gear of 7.18 with 3.73s. So if down the road you want to have some real fun, you can. Something that with the Overdrive box I could never make happen.
Of course your cheapest option is to just swap out those 3.55s. But then the combo usually gets a lil lazy, and the only cure for that is more cylinder pressure, or more cubic inches.
Lest you think I maybe had a POS engine, that sweetheart 367HO went 93 mph in the Eighth, pulling like a freight-train; not bragging, jus saying...
Dear Lord Jesus.
"THAT" said, the only point I'll make is that the A833 4 speed OS is NOT and never has been a "3 speed with overdrive". It is a 4 speed transmission and always has been. It has the A833 designation, which is Chrysler's designation for a 4 speed transmission. Call them what you will, but 3 speed is not correct.
I was given a 355 8 3/4 sure grip for free, upon disassembly I was told it looked in excellent shape and as if it. was never apart. Had it rebuilt and my mistake was not changing gears at that time
The reason was I had a car with a auto trans and 355 and it was no issue to drive at highway speeds so I figured in this current case it would be ok as well and with the 727 trans and it was
With the 727 i hardly realised the 355 was there
When I converted to the 833 which was also out of a 69 b body the same as my car, the driving experience was day and night and I enjoyed it except for the highway
Decades ago I had a plow truck with 456 gears with the SM465 four speed At 60 mph you couldn't hear yourself think. Now today I'll be dammed if this car doesn't remind me a little of that truck, not as bad but its reving and I don't enjoy it
I appreciate all the advise, im just undecided about Passion or Brewers..... Brewers I bought the entire conversion less the trans. I like them, the young lady who answers the phone is super nice as is Dan and the others.....Passion is also nice and they are within driving distance
Thanks again
Dear Lord Jesus.
Agree. Same with the 500 and 518 trannys. They are 4-spd trannys, not 3-spd with overdrive. A 727 with a GV OD is a 3 spd with OD. With that setup you 1st and 1st in OD. With the 518 and 833OD you don't.
Correctomundo as the Fonze would say.
There he is ladies and gents, the 318 hater now telling you how bad your OD trans choice is and what a looser you are for choosing it.
Tells us again AJ! How do you get more than 33 miles to the gallon?
If your just spinning tires, you have no control over your foot. Also, your tires probably suck. Possibly, even your suspension. And you blame it all in being “Just a Streeter” kind of a guy.
Yeaaaaaaaaaa LMFAO!
While I agree the ratios are far from ideal, there is always a give and take in this game.
