I'm trying to sort out my fuel gauge as to why it doesn't work.
Can someone please tell me what setting I should use on the
meter below to read the ohms at my sending unit in the tank.
Also where do I clip the red wire and black wire from the meter?
Everything I have tried only resulted in fluctuating numbers on
the meter that return to zero. I want to make sure my new sending
unit is working correctly before I go any further.
Thank You!
Thank You!
