sbh126
Well I finally broke in my 440 today with minimal problems. At least nothing major. First question. Some how I am getting oil on top of the valley pan towards the back. After running the motor for 20 minutes I had a nice little puddle and it was dripping onto my headers. Any ideas on where this might be coming from? And no its not from the oil pressure fitting thats back there. Already checked that one. Second queestion. After running my engine for the 20 minute break in I turned the key off and the motor kept on sputtering for about ten seconds until I put it in gear and killed the motor. Does this mean the motor is detonating? I had it set at 38 degrees at 2000-2500 rpms. It got up to 200 degrees and stayed there. I had half a tank of 93 octane with a bottle of octane booster added. I'm running stealth aluminum heads, kb237 pistons and have 10.7 to 1 compression. I was told I'd be able to run on 93 octane with my combo. was this wrong?
