Oil on your hedders?
TrailBeast
AKA Mopars4us on Youtube
Arizona
No I don’t pee the bed (yet):D
I use these when I change oil filters on small block Mopars with hedders.
Just lay one absorbent side up (plastic side down) over my down tubes to stop oil from getting on them.
Once the filter is off and the mounting surface is wiped off, just fold it up an toss it.
You can get them just about anywhere.
i also use them under my floor mats in the winter time it helps keep the carpet dry from salt water .
Pfft... I've always found the oil burns off soon enough, on its own. Solutions for a non issue
I bought a 24x36 floor pan and place them inside. Then under the car in the right places.
I too use them under the car when I do about anything that could result in oil, grease, dirt, rad fluid etc on the floor.
Super cheap on Amazon, $17. 00 for 50 pads
This was before the 2x3 trays
Great idea! :)
I use a piece of cardboard and crease it to form a valley.
Shove it up under the oil filter, and let the oil drain down into a container.
get 'em at .99, they are for dogs but they are the same ...maybe smaller.
Had the Dart out today, put fresh pads down.
Note the lines in the cement to insure alignment
Look on the bright side. When you do start peein the bed, you'll already be prepared.
We buy them for our little one incase he has an accident at night. Get the Goodnight brand from Amazon.
That's a great idea for the next time I change the oil on my 22 Ram.
