Wow, there's no way I would go through all the extra work of pulling the motor or dropping the K-member to change the pan gaskets. Each car and pan set-up is different, but it wasn't that difficult to accomplish with the motor lifted up a bit. It only took about 4 hours to do, 3 to take it apart, figure out I had the wrong gasket on there(I incorrectly used the one-piece Magnum gasket) and an hour to button everything up. I figure double or triple that time to pull the motor or drop the k-member and realign it.
The trick seams to be gluing the front and sides of the gasket onto the pan and the rear gasket onto the motor with your favorite sealant. that way they stay put when you are reinstalling the pan. Mine took about 30 minutes to tack-up and to stay put enough to keep the in place, while still remaining soft enough to mold properly when tightened.
