Oil Pan Plug Issue
dart14
kemblesville, pa
1969 318 in a coronet leaking oil from the plug. Tried a self tapper and the self tapping threads got eaten while inserting the self tapping plug. Purchased a helicoil kit from NAPA (1/2 x 20) for $48. Drilling out the hole (33/64 bit and another $20) seemed fairly tough but was accomplished. Tried to tap the hole and the threads on the tap got eaten. What is this reinforcement around the drain hole made of ? Need a top of the line tap ? Is there a trick to this ?
maybe it is in the heat affected zone from when the thread insert was welded in?? If you can weld, I would say to remove the old insert plate and weld in a drain bung that they sell for transmission pans or have a shop do it.
Buy a fine thread nut & bolt and weld the nut to the outside.
Speedway has pans for around $50 bucks before you pull too much hair out. Could try the welding options above, but sounds like my typical struggle of me convincing myself I can save $60 by buying a $19 tap and fighting it myself for 2 hours, then welding a nut on for an hour, then blow a hole through the pan, or the nut leaks....and could have had a new pan on for $50 in an hour lol. God I love these old cars...lol
my daughter drove my 88 silverado for a while in college, she had the oil changed at quick lube and they stripped it , I ended up tapping the hole with a 3/8'' pipe tap , and used a 3/8 pipe plug in in , no more problems...
I've seen those work for temporary plugs where you have a leaking soft plug. They can be VERY convenient if the soft plug is in a location which is really hard to replace properly without removing an exhaust manifold, or intake & head, etc
They're not ideal, but sometimes they can be a life saver.
I'd jump on that to get home! BUT, for a Continuous Immersion in a Hot Oil Bath? Err, ahh, ummm, No, Dammit! Hell No!
followed rustycowl69's advice and heated it up slow cooled as best I could and got the the tap to bite and completed the new threads for the helicoil insert. I tried cutting a helicoil down about 60% of the length, but I couldn't get it to insert and seat properly. Inserted a full helicoil and cut it off from the inside of the pan opening but it is still a little sloppy. Not satisfied with the threads on the original plug so I am going to buy a replacement tomorrow, snug it up, and add some oil to see if it holds. I thought about buying a replacement pan, but trying to keep as much original as I can, but starting to wonder if it is really worth it.
Thanks for the follow-up. Most of the time, we never hear the end of the story.
I'll be ecstatic if it ends up working for you. One of my wild a$$ ideas finally worked?! Hahaha.
