gunmetal72
Life is a dark ride
sorry, I guess it is called the windage tray. and no I was no thinking I would need o change the shaft that drives the pump but now that you mention it??
There gets to a point in some engine builds where a HV pump and a higher pressure regulation is warranted,and your engine is NOT one of them.
Whenever you ask about oil pumps you will always get those who straight away say" Oh I always use a HV with high pressure". The reason for that is because they simply don't understand where the oil pump fits in relation to the whole oiling system, so they go with what they consider is the safest option and usually it's the wrong option.
Anyone here who is telling you to go to a HV pump , don't know what they are talking about..
You should explain it to us then because my actual results prove you wrong. Once you go past stock rockers and spring pressures you need the HV/HP pump.
As I said, these are NOT chevies. If you are going to the trouble of going through the engine, you should use full grove mains. That, in and of itself should be the first clue for a HV pump.
I've explained this subject before, if you weren't here, then that's not my problem.
You want to tell me how using a different rocker and a higher spring pressure changes your oil pressure.. LOL.. just more BS. If your grooving the cam journal and having oil spraying out everywhere up top then going to a HV pump is not the fix, controlling the oil and putting it in the right places in the correct amounts / pressure is.
Patching up an oiling system that leaks like a siv , by throwing yet more oil at it is not the way to go. I don't know about you but when I build an engine I try to control and reduce the amount of wasted oil and windage going around in there. That's why the F.A.S.T racing hemi guys can run a stock 6 quart factory sump and not have oiling problems..
Full groove mains are old hat, I don't use them and I don't know many who do. Blowing oil past the mains just adds to more windage, more oil control problems and less power
As I said in this build he does not need a HV pump..
It is more of a point of maintenance and durability. The corners on the hex at the bottom of the shaft that engage into the female hex in the pump can get turned, and if bad enough and get loaded at high RPM's, they will evenutally 'smooosh' off and then the shaft just spins in the pump. There are shafts with hardened tips if you turn a lot of RPM's. Plus you will get a new cam gear on the shaft. Also, consider replacing the bronze bushing in the block in which the shaft rides, if you have it all apart. You can find both at Mancini.sorry, I guess it is called the windage tray. and no I was no thinking I would need o change the shaft that drives the pump but now that you mention it??
Thanks for this, I will take a look. I am also told I need to change the cam gear because I am going to a roller cam. Kinda makes sense to change the shaft and bushing. I am still unsure of the HV oil pump. There is allot of guys that have different opinions on what pump to use. I am of the mind that it would be a good thing to use a HV pump but keep the low pressure spring. The clearances of the engine will be small so it should have good oil pressure but having more oil flowing at low RPM would be the big benefit. So I am thinking that is the route I should go.It is more of a point of maintenance and durability. The corners on the hex at the bottom of the shaft that engage into the female hex in the pump can get turned, and if bad enough and get loaded at high RPM's, they will evenutally 'smooosh' off and then the shaft just spins in the pump. There are shafts with hardened tips if you turn a lot of RPM's. Plus you will get a new cam gear on the shaft. Also, consider replacing the bronze bushing in the block in which the shaft rides, if you have it all apart. You can find both at Mancini.
Perchance are you using the SCAT type I-beams rods? If so they have a LOT larger big end side clearance than the stock rods, and will flow more oil out there, 'specially at higher RPM's when centrifugal force tends to fling the oil out of the rod side clearance. That would call for better flow to the rods overall, including the pump. Just thought I'd ask since you are going to a roller cam.Thanks for this, I will take a look. I am also told I need to change the cam gear because I am going to a roller cam. Kinda makes sense to change the shaft and bushing. I am still unsure of the HV oil pump. There is allot of guys that have different opinions on what pump to use. I am of the mind that it would be a good thing to use a HV pump but keep the low pressure spring. The clearances of the engine will be small so it should have good oil pressure but having more oil flowing at low RPM would be the big benefit. So I am thinking that is the route I should go.
There is a fair amount of misconception going on about these pumps.
1. The theoretical difference in flow volume of the HV pump is 20% over the standard pump, and have been advertised/measured at 18% or so over the standard. But that extra only flows into the engine in a limited, lower RPM range.
2. Once either pump's output pressure hits the relief spring limit, then neither pump flows more than the other into the engine.... either pump at that point will provide whatever oil the engine's oiling system will take AT THE RELIEF SPRING PRESSURE, and the rests just recirculates inside the pump via the relief valve. The HV just recirculates more.
3. The HV pump will put out more pressure at the lower RPM's and reach the pressure limit sooner than the standard as the revs increase. So for equal relief springs, the HV has that advantage and will thus flow more oil into the engine AT THE LOW RPM's; I can't see any thing but good from that for typical engine use. And if the clearances are bigger, then it will help for sure.
4. As said, once the relief valve opens, they flow equal amounts into the engine, so for exclusively high rev use, the standard pump won't flow any less than the HV pump, and the standard pump will take a little less power to turn, which may matter at over 3000 or 4000 RPM, but would be of no consequence for street cruising.
BTW, we recently bought a Mopar Performance HV pump, and it actually was a Melling with the higher pressure spring. There was no need to mod the oil pan. It is a stock 273 pan on a 340. We kept the stock pickup.
Any other mods like grooved cam bearings in 2 and 4 positions?
OK, gotcha. Very good. Any reason to use the 65 cc 60175 heads vs the 63 cc 60775 heads? The 65 cc heads have the pseudo-open chamber area opened up in them that pretty much negates any quench gap. If you are zero decking the pistons in the block (or getting close), then you can end up with a good quench gap with the standard .039" Felpro 1008 head gaskets if the 63 cc closed chamber heads are being used.That buys some more detonation resistance and helps burn effiecieny. Either way, you should be on target HP-wise for sure. Nice combination (IMHO).
And BTW, if you have not bought your heads yet, MAYBE today is the day! Autozone has their 35% gift card discount for on-line purchases March 3-4, and you can get back a gift card of around $560 for those heads, enough to get the intake plus more goodies like engine gaskets for free. (Free shipping in the US but you do have to add in your local sales tax if they have a business presence in your state.) BUUUUT, I see you are in Canada....so I am not sure if that all applies for you.... it's worth checking out.
Well, the standard dimension of the big end width posted on the SBM SCAT rods works out to .026" side clearance..... which is spot on with what we got. So maybe they changed them since you used them?? .035" sounds WIIIIDE for a stock rod big end....
I have sucked a pan dry racing after 2-3 minutes at higher RPM's but it was not a Mopar. The design did not have any flow restriction in the head oiling feed passage.
Hunh, I never knew that on those engines. No, it was an Opel 1.9L cam-in-head (70's vintage) that I rallied for years and years; I happened to leave in a relief spring shim in a pump and was in a hurry to start racing and did not hook-up the oil pressure gauge; turned out I had over 100 psi....oops! The Vega engine was known for the same thing if you ran it at high revs and too much pressure.Ford FE engine? Only thing I can think of, just put smaller restrictors in my wife's 390 galaxie...
My camaro has a HV pump in it also, really havent seen an issue with it
