on 1971 340 ci do not have old thrust plate and bolts so I ordered new type with chain tensioner my question how does the chain get oil to it and should I seal the 2 oils holes behind new plate also should I seal Thrust plate to block .Thanks
I've seen precious few that had plugs at all. Most I've seen used the cam thrust plate to block the oil galleys off.So, I guess you would leave One of the Galley Plugs Out behind the Plate too?
Just like that^^^^^I drilled a hole through the cam plate and then drilled a small hole into the plug behind it. Just make sure you drill the hole in the plate smaller than the outside dia of the plug. You don't want it coming out.
Thanks for the response I agree I did want like using thrust plate with tensioners but that is all I can find. What size are the soft plugs for oil holes as the block I am working on does not have them
It totally depends on which double roller chain it is. Some work with the tensioner and some not so well.I am not 100% on this but I remember something about NOT using a tensioner with a double roller chain set.
No way would I use a tensioner. A quality chain and no need. What is the wear area on the tensioner made of? And where does it go?
The tensioner is made of UHMW. It work hardens. Think about all the SOHC and DOHC junk out there using tensioners and roller timing chains. No sense to not use a tensioner.
I agree with Steve, buy a good quality timing chain and gear set- up to start with. And a course one with multiple keyways, you are going to check valve timing right and make the necessary adjustments right? This picture clearly shows the wear the rubbing blocks left by the chain, this only in about three years of cars shows and occasional drive. While I do understand the wear marks on the pads, but there small chunks missing in the plastic grooves the timing chain have left…not so great.
The tensioner itself is well designed and will work great if used with the correct chain.. a link chain or “silent chain”. This is nicely illustrated in post # 14 the pads now have the full backing of the chain instead of 4 rows of timing chain links.
Needles to say this set up will be going into the trash bin, and I will be going with the stock cam plate and oil baffle plate and a hole in the bolt configuration.
Merry Christmas and a Happy New Year.
Yeah my brother used one on his 408. After he blew it up we looked at it it looked fine.Running a Mopar Performance chain tensioner with a Summit billet chain set. After a few years (albeit low mileage, maybe 8000 miles?) and then a cam swap the pad the chain rides on only showed scuff marks, no gouges, signs of melting, chunking, chipping. fractures or fissures, hair line cracks lifting or looseness. I don’t attribute it to just rare luck or being an exception to the rule. IMO it’s the opposite. It’s typical and to be expected. Unfortunately people have had issues, but fortunately they are in the minority, only getting amplified on various forums
We're gettin sidetracked talking about tensioners. The thread is about chain oiling.
