68dodge
If someone has installed the 10127 kit. My question is with the Hazard Switch section. You have to install the # 951 blk wire to the ignition wire section for the steering column. The white wire for the brake switch. Now do you leave the right turn,(tan wire) and the left turn(Lt Gr wires) from the hazard section disconnected, since your turn signal wires are connect in the steering wire?
