Johnny Dart
Yep, Go Seahawks ! lol
and I'll keep on doing it, because I'm an old stone headed dullard. LOL
Who ?
We're not worthy, we're not worthy....I was thinking the same thing... what the hell happened to the snowmobiles and reefer talk lol.
I wont derail thread until tomorrow when it dies or doesn't die on me...
I’d find something in a 10W40 or if you’re really into emptying your pockets, you can use a 5W40 100% synthetic and it can’t be a cheap oil. When the spread between the winter grade and the 212*F grade is that big, the additive package and even the base oil (which is the Winter grade and the additive package makes up the high side) has to be very good (and that ain’t cheap) or the oil will have a short life, and it won’t take long before it’s job.
In fact, a very good 5W30 would work for you, but again, that ain’t cheap.
The Driven oils are damn good for their price point. I can’t remember what it is, but I think 7 or 8 bucks a quart so it’s not outrageous.
Since I run a 5W30 and I’m dropping down to a 0W20, the oil I use is double damn expensive. I think it’s 22 bucks a quart.
That’s a lot, but I’m going WAY down in grade, plus I’m running a pretty aggressive solid flat tappet lobe, so I don’t mind paying it.
The Driven should be more inline with what you need, but not a 20 winter grade and not a 50 grade, unless you’re clearances are outrageously loose. Like .003 or more.
You're what?We're not worthy, we're not worthy....
Talk like this will put you on my favorite member list.... That may not have sounded right..
I normally go in with the part number. 822388 is their part number for 10w-30.Thats what i had in it the first time I changed the oil, the car seemed to like it? But they didn't have it last time I got oil.
I have adhd and I'm dyslexic!! Its hard knock life for me for me..... oh looks a squirrle!It's a common thing in adults. More so than most think. My son is 30 now and had a bad case of it. I was serious when I said that, I wasn't making fun. I have a lot of experience with it and can spot it quickly.
With that said, don't let these yahoos veer you off track. You may have a small overheating issue, but it's certainly not enough to warrant changing oil grades. Were you running 900 plus HP in a big block with LOTS of heat buildup, then you might would want to look for every avenue to help run cooler. You're not.
You're what?
DD, I hope the dying issue is solved and the cooling issue is a simple one for you!
Did it die? The coil buzzing is an odd issue. It seems like something is wired wrong (which you've gone over and I believe it was sorted) or a possible ignition module problem making the coil buzz constantly.
you know who and you're gonna know who here shortly. lolWho ?
The biggest problem I have tracing the wiring is I dont know anything about the stock harness.
Well go back and read what I posted, and that includes the diagrams.this little black thing
Sure as hell can't be more difficult than learning how all the thingamagigs connect to stuff inside a persons mouth.
I also don't hear a buzzing... that may be attributed to the ecm or it may be attributed to the no starting problem. There is fuel in the carb, I watched the fuel shoot into the carb when I pressed the throttle lever...
I believe the ignition module needs to be grounded (the actual body). Of course, new parts can be crap right out of the box. You just disconnected the old and replace it with the new right?It started for a split second and instantly died. So there is probably a bad connection somewhere.
I won't derail again, I just wanted to remind Johnny.
Yes I disconnected the old ecm and installed the new one. I was thinking maybe it was getting a bad ground on the body due to the paint (even though it was in the same spot).
