Keep your eye on the big picture.
I keep hearing how much you like your 318s;you do realize that a 390 is no longer a 318 right. It has just 23 cubes on a 4.04 bore 367.That's a tic over 6% and it's all stroke. And cam for cam, in street trim,that's about 23 to 28 horsepower over the 367, or about 7 to maybe 12 degrees in intake duration, depending on optimization.
As to torque (low-rpm power to member 273), the 390 could waste the 367, alrighty........ but a stout hi-compression, aluminum-headed, 367 already makes way more torque than the stock street chassis can handle. So by installing the stroker kit, you could actually be just buying tires more often.
However, if this engine was for a heavy truck or van, or if you actually just want a tire fryer, well then shoot me now.
Or I suppose you could take 10% rear gear out of it and still be on par with a stout 367. It's just that the 367 was a lot cheaper to build. Last time I looked stroker kits were going for about $1200 and more.
That money could go into a proper TC for a 367, and gears, with some left over for a shiftkit and a cooler.
Now, hang on, I'm not dissing your choice or raining on your parade, or being a killjoy. Not at all; I'm just trying to help you get the most from your dollars.
And to that end, if you do go 390, then again, to get the most bang for your buck, for sure get aluminum heads, and crank the cylinder pressure up to match a small street cam. This might allow you to keep your current TC , and run 10 to 15% less gear as well, cuz no matter what, it's gonna spin any street tire you can fit into any stock A-body rear tub........ So, you might as well shoot for some civility and fuel mileage. In that way you can trade the Crank kit for a TC+gears, making it all the more attractive.
But if you're stuck with iron heads, you'll have to keep the pressure down, and you might nor be able to keep the current TC and gears.
The point is to just see the whole picture.
