Piston swapping
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
I have a question about some Std bore 340 pistons.
Will tese work in a bored 360 ?
Is the pin a different hight?
Whats the story ?
I have 2 new sets of Domed std pistons and trying to figure out what to do with them !!!
It depends on which ones they are. Tom Hoover did it back in the day when no pistons were available for the 360 and built the Hoover 360. If I remember right the Hoover recipe was a .040 over 360 block that used the lower compression 4 eyebrow 340 pistons. That got compression up to around 12:1. I don't think it would work with domed pistons.
And IIRC, he had to cut a ton off the (low compression) piston tops just to get it down to 12:1 with the 360 crank.
You'd have to mill the domes SLAM off of um and "maybe" a little more. They might be thick enuff, though.
There's no cheap way to use those in a 360 block. The easiest would be to get bearing spacers and put a 3.31 crank in a 360 block, bore it .040 and sock it together. You'd have to use open chamber heads though. Might be easier to see if The Smithsonian needs some ancient pistons....lol.
Well I guessing these are pretty much a lost cause. Thanks guys.
Hang onto them.....somewhere, there's a dude with a new R or X block that is stuck in 1975 and looking for standard bore 12.5-1 pistons....lol. The bearing spacers would seriously work to put a 3.31 crank in a 360 block. Last I checked, they run around $400 for the spacers.
Whats the story ?
Surprise. Well you learn something new about somebody everyday.
