Please Clarify..
1968 Valiant
Seattle
Will I be able to retain my blower fan and colum shift (automatic) with my 440 swap coming up???
These two issues are deal breakers for me.
The blower fan is not a problem with stock valve covers. I've never tried to build with a column shift, but it can't be done with B-body HP manifolds. I think it will fit with some headers.
I think with an RB you might have to tweak the cover to clear the blower motor. I have done the column shift with manifolds easy enough. But once you replace the manifolds with anything other than fenderwells you have to ditch the column shift.
I had 0 issues with either on my '72 Dart/383 project....
BUT I used Factory 1968 A Body BB Manifolds.
Later,
Bruce B.
Moper is correct...I had to ditch my column shift and install a floor shift to clear the Schumacher TRI-Y's...8) Mine is also a factory A/C car and that changes everything also...I notched my cast aluminum ones in my car to clear the blower motor
Thankyou all. I am going to try and make them both work. I am stuck on the column shift because I have a weird obsession with very stock looking but very modified cars.
My Valiant is a four door and I picked this over a 2 door. They are far more useful as a car for as much as I drive it and no-body expects to get caught off the line by one. The 440 I am prepping to install will be as quiet as possible and as stock looking as I can make a RB look in an A-body.
Most my "car friends" would not know the differance and all the older mopar guys wil get a kick out of it.
What are you going to use for exhaust off the heads ? headers or manifolds ?
I was under the impression that Headers was my only option. Is there a manifold that works with the 440??
If not I was hoping to try the tri-y Headers
B-body HP manifolds fit with a little work.....BUT you'll have to lose your column shift or make changes to it.
There was a source off BBDart.com that sold HP manifolds that have lower sections replaced with tubular steel that will also fit. My buddy has one I think it's the left side that's modified. Any right hand HP (B/E/C) will fit easy enough.
