Post Your Hoodscoops
My 69 Barracuda, 5: tall Hemi Scoop fro AAR Fiberglass.
Here are the first pics of the outer shell of the scoop. I originally was going to buy another hood and chop it up to get the same leading edge as the main hood. I want to keep that line about the scoop. It was too hot to play outside after lunch so I tried my hand at recreating the hood shape.
I still have to break the 1/2" flange so the scoop will be that much shorter.
It will also have something similar to an air grabber in the center of it for a ram air function.
Andrew
The aspen and the dart.
The Aspen is a glass cowl that I bonded to the metal and cut a nice sized hole in the hood for so it functions properly and the dart has standard 340 scoops with 4in holes because 4 1/4 hole saws are more expensive.
Here is mine.It is all steel including the scoop which a friend made for me from the factory spec's.JEDS67
I took a 67 hood and turned it into a flat hood.I also like the E body shaker and rallye hoods on the other A-body cudas.
Personally I would prefer no scoop. I couldn't get the engine low enough in the Scamp though because of clearance issues with the starter. So I bought a small, 2.5" bolt on cowl scoop from Jegs. I had to flatten out the character line in the hood so it would fit right. It just clears the vent tubes on the carb.
I would have used the same scoop I had on my Duster but it's not tall enough in the back.
Mr. Jones
No its not, there just happens to be a rip in the fabric of space right about there:toothy10:
Andrew
dude...your bumber really is on upside down?
Mr goodwrench's body shop assured me it was the way to go. :cheers:
You guys need to go to the thread about my new front spoiler, maybe that will help.
Andrew
I think this hood adds a whole new look, I prefer it to stand alone and it does beautifully!!!
