[WANTED] Pressure plate bolts.
circlepilot
El Dorado, Arkansas
I believe I have looked everywhere. I need a source (part number) for 5/16" 18 X 7/8"L , 3/8" 6 point, flange bolt for my pressure plate.
Norm
I don't think those are correct. It says they have 1/2 inch head. The slant six with the 10 inch clutch needs the special bolts with the smaller head. If using the "regular" bolts, the disc will drag on the bolt head.
Yup, you are right. That's the smallest head bolts I could find.
Looks like a header bolt.
Try finding an allen cap screw with those dimensions ?
The bolts need to have a shoulder to align the pressure plate to the flywheel. Brewers Transmission will have the correct bolts. Your flywheel should have a stepped hole for these special bolts. Again you cannot just use a small header bolt. The threads are 5/16 but the shoulder is 3/8 and take a 3/8 lock washer.
I made a post regarding that, but the mods decided it wasn't important and removed it. Thanks for reposting that pertinent information.
