problem with indy heads?
boozersdart
Active Member
I was planning on buying Indy heads 360-1 and was going to have them fully ported, then I read some bad reviews about them leaking coolant in the oil through the casting and they said that indy would not do anything about it. Has anyone using indy fully ported heads having any problems with the heads or indy as a whole.
whatever you do... DO NOT buy direct from indy!
Buy from a dealer.
Would you recommend hughes engines as a dealer for indy heads?
Thanks for the input.
If you're in Illinois Bob George Racing or Best Machine could set you up too.
