Anyone out there running reproduction steel wheels. I’ve got some 15x10 repros and having a problem with damaging lug nut/studs. Correct lug nuts torqued correctly. Oem drum brakes but later from Cordoba. Only thing I can figure is the design of them they have a “ring” on each side of lug nut land that prevents that area of rim from seating against drum or rotor allowing them to move when I put the hammer to it. I’ve got some older oem wheels sitting around and they sit flush in that area but they aren’t the style of what I’ve got. I’ve installed centerline convos which aren’t bad but really liked the dog dishes. Borrowed wheel pic from else where. I’m suspecting the metal gauge is different. Anyone else have this issue with reproductions?
