This tutorial states the rocker tip contact should be changing directions during valve opening/closing (my bold print).
From dvorakmachine.com :
OBSERVATION AND CORRECTION
NUMBER ONE PRIORITY is to ensure and correct as necessary, the relative valve tip heights (fig 1). The closer you can get them to each other, the better the effectiveness of your efforts.
This can be accomplished by doing the valve job, install the valves, locate the one that sticks out the farthest, and then go about the task of matching the "short" ones to the "long" one. This can be accomplished by regrinding the seats, grinding a wider 45 degree angle on the valve, effectively reducing the margin of those valves, and in some severe cases, adding a lash cap to the tip of the valves to make them think they are "longer". You can also dress the tips down of the longest valves if that helps equalize them. CAUTION, LIMIT WHAT YOU REMOVE OFF THE TIP OF ANY VALVE to about .020".
ONCE YOU HAVE EQUALIZED THE TIPS, you are now ready to deal with the geometry and scrub angle.
It is best to install the lightweight "checking" springs for this procedure. Actually, you need only start out with a pair of valves, one intake and one exhaust, a shaft, two shaft hold-downs and of course two rocker arms. For the purposes of this discussion, we will concern us with standard ADJUSTABLE IRON ROCKERS, such as Isky, Crane or other MAX-WEDGE type rockers. These are the most common street type rockers and offer tremendous gains over the OE stamped steel models.
It should be pointed out at this point that roller- tipped rockers have the same geometric requirements. The procedure to correct the scrub angle is similar, but small amounts of imperfect geometry can be tolerated much better than their cast iron counterparts. A roller tip does not actually "scrub" as we have been defining it, but rather the tip ROLLS across the tip of the valve instead of "pushing and/or pulling" as FIXED tip rocker arms do.
We do not like roller rocker arms for street use. Especially aluminum bodied ones or needle shaft mount rockers. If you feel strongly about using ROLER ROCKER ARMS ON THE STREET, I would recommend the Comp Cams Steel bodied roller tip. Use the same procedure to identify and correct geometry problems.
WHAT YOU ARE LOOKING FOR
For the purposes of identification we will break the tip of the valve into 3 parts. The center, the shaft side of center and the exhaust manifold side of center.
The old theory of having the center of the valve contacting the center of the rocker pad (roller) at one half of valve lift isn't close enough, at least with a stationary tip rocker arm. What you are looking for is the action of the rocker arm across the valve tip that changes direction as the valve opens. The action will appear as rocker tip moving across the valve tip and then back.
The center of the valve tip should start contact (at zero lash) slightly to the shaft side of center. As the valve opens, the center of the rocker arm should move toward the center of the valve (or just past it) and then at some point, reverse direction and come back to where it started when the valve is fully open. This action spreads the load against the guide and averages it out.
Improper geometry will look like the rocker tip is scrubbing toward the exhaust manifold side of the valve tip for the entire lift cycle OR PULLING back on the tip of the valve toward the shaft side during the entire cycle.
IT IS IMPERATIVE THAT THE TIP OF THE ROCKER CHANGES DIRECTIONS AS IT "SCRUBS" ACROSS THE VALVE TIP.
A roller tip rocker is okay if the roller center is on the center of the valve tip at half lift in most cases. Raise (with shims) or lower (by machining the pedestals or the shaft stands until you can accomplish that position. But if you observe the movement across the valve tip it should do the same as described for the stationary tip rocker. And that is start contact to the shaft side of the valve while the valve is closed, move across the tip just to center or slightly past, and then return to the original position during full lift. Then back to center at one half closed and back again to the original position when the valve is closed.
It sounds complicated but it is not. Put a checking spring on the valve, adjust the lash (or pre load) and rotate through a few cycles and you will be able to identify what is happening to the scrub angle. It will become clear to you and what to do about it will come easily.
Take care of this important part of the engine build. Your valve train will love you for it!
