68dartgtman
Does anyone know a good source for locating a replacement push button heat/ac module? Mine is broken and have not seen any from any parts vendors - new or used?
thank you !
			thank you !
Hey, thank you ! Mine is a 5 button - I'll look at Paddock and Echlin - I haven't pulled the unit out of the dash yet - I assume it's broken because 2 buttons are stuck in and 1 of the 2 is crooked as a dogs hide leg ! so I think it doesn't look good. I am hoping I can repair it if it's not to bad but know dodge/Chrysler used this unit on a lot of other models - my dad had a 67 Cuda fastback that had the same setup and have seen it on other models also. Just may have to go searching for this if not repairable !
Thank you for the info !!
You can epoxy it too, put paper clips in the holes so they don't plug up, then use JB weld. I repaired my broken 62 Chrysler 300 that way.
Yes that should work. Mine was leaking internally so I had to buy a new one. I drive my car daily so I also didn't want to have everything disconnected while I fixed the part. But sometimes you got to do whatever it takes.
treblig
