PUSH ROD OPTIONS FOR 318 WITH EDELBROCK HEADS
Rob38e
Chula Vista , CA
Hi was curious to know whether anyone knows the specific height for push rods on Edelbrock #60779 heads pre (assembled) with valves and spings. I currently have the stock cast iron and swapping to aluminum. Will this also depend on the camshaft size ?? Which is also being upgraded. Lastly, can I use the stock rocker arms.
**318 engine , any insight would be appreciated
Yep, have to get a pair of adjustable pushrods to check for length. Putting a set of stock type rockers on a set of edelbrock heads, unless they have all been checked and confirmed to have equal ratios, is throwing good money away that should go to a set of aftermarket adjustable rockers. But if you're actually using enough cam to take advantage of the Eddy heads, the pushrods will punch through the stock rockers anyway.
Contact Don at a company called OE Pushrods. They make 80% of the pushrods for the aftermarket companys. Save a ton of money. And if your nice he will throw in 2 extra ones. Or go to the online companies & pay there x3 mark up price.
I had good luck with Smith Brothers-----------Good service and fair pricing I thought. Sent me an adjustable, told me how to measure and built my pushrods to the correct length.
The whole thing took about 10 days.
OE pushrods can be found online. They are 5 miles away from me. And mine took 3 hrs. But they went to lunch during that time. Lol
Mopar used to sell a cut-to-length kit that you could assemble yourself. My 367 has one of those in it. It comes in handy if you need to swap to thinner gaskets, just take 'em apart and trim as required.
But; did you know, on a 3.91x3.31 teener, in a streeter;
60779s will drop your Scr to around 8.85 with stock flat-tops .057 in the hole. Almost any performance cam you run with that will have a soft bottom end. The 340 cam for instance, will drop your cylinder pressure to less than 135psi@800ft elevation, worse as you go up. This is a direct low-rpm torque loss, and will require a hi-stall to overcome. In the meantime, your fuel-economy will tank. Have you taken steps to overcome that?
Those aluminum heads are nice,(I run them on a 367) but for best results, the pressure needs to get up to around 185psi. At the low Dcr of 7:1 that the 340 cam would make, it's gonna take quite a bit of rpm to wake then up, say 4000 with that 340 cam. Which with say 3.23s, will begin to come in around 40mph with an automatic in first gear.The cure for this might be 4.10s, to bring 4000 down to ~31mph; still quite a wait. 'Course if she's spinning, none of this matters...... but spinning is the slow way to anywhere.
Below 3000 to 3300rpm, if not spinning, it's gonna feel like a tired stock 318.
To get to 185 psi with the 340 cam, would require ~11.2 Scr. Which with a stock 318 swept of 652cc comes to a total chamber volume of 64cc, requiring a much smaller head volume. In fact, you can't get to 64cc with flat-top pistons down at .057 (11.2cc), with any heads period. So the first order,IMO, is to get the pistons up to zero-ish, then with the .039 gasket(8.8cc), you would need 55.2cc heads..
To use your 63cc heads you would need 8cc pop-ups on those zero-deck pistons...... The Q is already at gasket thickness of .039, so that's gonna take a funky custom reverse-dome piston to achieve. Or some combination of dome and head-milling.
Do you have to run 185psi?
No,of course not.
But the V/P index at185psi is 138, just enough to have fun with, with say a 2800TC and 3.91s.
Read about VP here; V/P Index Calculation
So if she makes only 170 psi, you might as well have stuck with iron heads at say 160psi. They might make the same power, better low-rpm torque, and; 160psi is way easier and cheaper to achieve.
A better idea IMO,in order to use a 340 cam,, is to start with small-chamber iron heads, and or forgo the Mopar 340 cam all-together. There's lotsa "better" less pressure-hungry performance cams out there; I used probably one of the worst examples I could have, just to drive the point home, and because that's what everybody seems to want to do.
No,of course not.
Gotta love Victory Library, thanks for the link, it’s been a while since I got to review that one again.
Comp sells the parts so you can cut and build your own. My first set of parts arrived in a day from Summit and took 5 hours to build . Takes moderate skills
