Tiki bar jim
Anyone in A Body land have any opinions on the Quick Jack lifts?
TIA
TIA
Photo or a link please.Anyone in A Body land have any opinions on the Quick Jack lifts?
TIA
Is that the one you put a floor jack under?I have a Kwik-lift, pretty sure it is different than what you are talking about...
Doesn't look like it actually leaves you much room to work under the vehicle, either.Just my opinion, but that looks cheaply built.
8000TLX Portable Truck Lift
The QuickJack 8000TLX is our most powerful extended-length portable truck lift, built to handle up to 8,000 lbs. Its 76-inch frame and 66-inch lift point reach make it ideal for long-wheelbase trucks, SUVs, and large sedans. Despite its size, it still fits under most sports cars with ease...quickjack.com
YesIs that the one you put a floor jack under?
I looked at those just now. They've halted production because of steel prices. But, they are only rated for 5K pounds. That wouldn't get my truck. Dangit.
I like this design. If it had a higher capacity, I might have to save up and get one. It would be great for alignments.I have a Kwik-lift, pretty sure it is different than what you are talking about...
My local Craigslist has a couple for about $1500. I’ve been eyeing them for a while but haven’t worked up the courage (dough). I figure I’d rather spend the imaginary money on car parts.I like this design. If it had a higher capacity, I might have to save up and get one. It would be great for alignments.
Quick? Ummm.........nope.Doesn't look like it actually leaves you much room to work under the vehicle, either.
I wonder if you could use some 4 x 4 blocks?Quick? Ummm.........nope.
It's secure when setup right.
Actually, it's a bit tight but I can still use a creeper under mine.
You can turn these sideways if needed.
For grins I tried to lift my Ram with it. I wasn't tall enough to get the rears off the drive........
