stroked340
I prefer green bearings only...
I'd like to hear if any one has had failure with the Greens... I could not seem to find any negative feedback..?
Let's sum this up.
We've established the newer green bearings only fail occasionally (just check the track record on newer cars) but are probably O.K.
..how many parts do you want on your car that are probably O.K.
so you are saying a timken bearing has never failed?? i find that kinda hard to believe.
I have replaced a boatload of them through the years.
I am sure this has been brought up before. What is the better bearing and why? I am rebuilding a 67 b-body 8 3/4 for my duster which will be daily driven. I drive the car hard and play even harder. I will be running a 741 case with sure grip and currently running factory 10" drum brakes. If it matters, the car has a mild 340 with built 904. I plan to run 15" wheels and SS springs with rear sway bar.
Thanks in advance for the thoughts...
IDK
Is there a third option?
Im too lazy to adjust those funny looking ones, once every 5 or 8 years, and Ill probably never change my rear end( Im happy with the 2.45s). I like to autocross every other weekend, and the in-betweens, I will be drag-stripping it! Got a turboed 379 in er.During the week I drive er to work every day. Its a straight shot, but about 50% is a little twisty. I like to take the little ones camping, now and then, and will be towing a 40 ft camper. I think the 379 can pull that at 80 no sweat. So all in all, I think thats about 30% twistys, 30% straight,and 50% everything else.No A/C. Am-Fm if it matters.( But the in-dash speaker dont work so good any more).So any ideas for my 8 1/4?
Aw shucks, thanks.
I was beginning to wonder if anybody still reads my posts.
Do I get a prize?
DoIDoIDoI,Huh?
