Rear Gear Oil Change and New Seal 1973 Dart
Mike's Dart
Dodging The Negative Darting Toward The Positive
McDermott, Ohio
Gave the /6 a new filter and 4 1/2 quarts of fresh oil today! Now on to the rear end and an oil change and a new seal! Any advice on the best rear gear oil to use and how much I'll need? Anything I should know prior to getting into this rear gear oil change? Thanks in advance!
Mike
what size rear? does it have a crush sleeve?
Wow! Did not know there was so much to this rear gear? I'm not an automotive technician, so I guess I'll have to do a bit of research. Owners manual, VIN number? Stamp on the axle/rear end?
It's a little easier if you just want to change the gear oil and not the pinion seal. If the pinion seal (around the area where the driveshaft attaches to the rear diff) is not leaking, there's no need to go into the hassle of replacing the pinion seal.
If it's an 8 1/4 (8.25) you remove the differential cover off the back and the fluid will drain out. Remove any remaining gasket material on the cover and the differential housing and replace the cover gasket with a new one. It should take about 2 quarts of 85W90 and if you have a locking rear, you'll want to add 6 ounces of limited-slip additive before the gear oil. There's a fill hole about halfway up the side of the differential. Add gear oil until it runs out the hole!
...and in the words of our friend Del (67Dart273), head over to MyMopar - Mopar Forums & Information - Service Manuals and download a service manual.
Thanks for the Service Manual down load guidance and rear gear advice! Much appreciated!!!
Mike
The cover on my 73 Dart's rear gear has 10 bolts, so what size differential do I have? Thanks!
Mike
Should be an 8.25
You're welcome. Let us know how it goes! There's nothing quite like the smell of old school gear oil :)
Will do! Fellow at the parts store said to be sure and not get it in my hair! The look on his face lead me to believe his advice was "spoken" from experience! :)
