Well The Tear down and Inspection/Discovery stage has started. After peeling back some layers I was able to access the two bolts that attach the hood latch mechanism and remove them to
get the hood open. Slowly progressing and taking tons of photos for insurance purposes. Down to the Core support on day one, Right Frame rail is definitely tweaked! Inner fender is distorted in the front and
bowed into the engine bay on the bottom spot welds failed. The mounting area for the bumper bracket is not flat as it should be and the rear lower side of the fender is pushing out and away from the body line with the door.
The Bumper was in strong tension as I started to remove the bolts. Once all the nuts were removed a well placed smack with the BFH did the trick to release the tension! I think the Left Grille Survived, maybe
a rechrome on the bezel. Still evaluating if anything other than the Parking light and bracket is salvageable on the right Grille. Both Eyebrows Survived! Fenders, Headlight Buckets all seem to be just fine, None of the
mounting bolts show signs of movement. Core support is slightly bowed in at the top and heavily at the bottom and lower sides. Oil pan is shoved back and Up into the crank case, Was able to bar the engine about a 1/2
turn before it locked. Tranny pan looks like it did not get hit and all seems good. My GlenRay Radiator took a hit from both sides, never saw any steam and no AF at wreck side or at my house. I will have it pressure checked
for sure. The impact pushed the hood back far enough on the right edge to impact the cowl yet relaxed back, WTF? All in all so far, I am more relieved than I was after the wreck and "Calypso" will prowl the streets once again!
Likely in a tamer appearance. The Link below is the Thread on the Wreck!
Did I get to "Greedy" Today? Did a double car show Saturday and the ending not so good!
