restoring faded rear plastic side panels
Convertible A-Body Mopar
  1. Dave NEO
    Dave NEO Well-Known Member
    854
    164
    Jan 6, 2017
    midwest
    Local Time:
    8:57 AM
  2. Alaskan_TA
    Alaskan_TA Well-Known Member
    4,350
    2124
    Nov 12, 2004
    PA
    Local Time:
    10:57 AM
  3. Mike69cuda
    Mike69cuda 63 is the new 17 FABO Gold Member
    524
    319
    Jan 2, 2018
    Overland Park Kansas
    Local Time:
    9:57 AM
    You might try vinyl paint. I have had pretty good luck with it. Very durable. Some colors of it cover better than others. You might try it on the back side first. Oreilly sells it.
    • Agree Agree x 2
    • Dave NEO
      854
      164
      Jan 6, 2017
      midwest
      Local Time:
      8:57 AM
      interesting, thnks. Am trying not to paint it though. Will be last resort - have used cheaper Krylon Plastic paint on other stuff with good results. Got all winter to mess with it I guess..
    • 66fyssh
      66fyssh Don't Stop Believin' FABO Gold Member
      3,744
      1808
      Jun 22, 2013
      Northwest GA
      Local Time:
      10:57 AM
      I agree with the vinyl paint. SEM makes great stuff. Use the prep stuff (or whatever they call it). And make sure you clean, clean, clean first. I changed door panels from red to black about 5 years ago and they still look great.
    • Mike69cuda
      524
      319
      Jan 2, 2018
      Local Time:
      9:57 AM
      Yeah, I used the vinyl paint on a boat seat. Lasted for 30 years without degrading. Cleaning is definitely the key.
    • Lee Robinson
      Lee Robinson FABO Gold Member FABO Gold Member
      5,830
      209
      Aug 23, 2009
      El Dorado Hills, Ca.
      Local Time:
      9:57 AM
      SEM makes good products. As some one stated above, use their prep products and follow the directions.
      Often times you can get a close match in an aerosol or have the color mixed. Best choice for variety would
      be an automotive paint store.
    • pishta
      pishta I know I'm right....
      14,044
      3726
      Oct 13, 2004
      Tustin, CA
      Local Time:
      7:57 AM
      just straight plastic? There is a rubber/plastic refinisher that works like magic on rubber bumpers.
      • Like Like x 2
      • pishta
        14,044
        3726
        Oct 13, 2004
        Tustin, CA
        Local Time:
        7:57 AM
      • Dave NEO
        854
        164
        Jan 6, 2017
        midwest
        Local Time:
        8:57 AM
        BTW, used some VHT Vinyl Dye with super results on soft vinyl like my sun visors and a motorcycle seat - really good stuff fwiw. With this type hard plastic though, I really want to get it right with correct paint if I do it. Someone suggested using a good metal polish first to see if the mild abrasive in it could bring out a shine/luster. Might try that first. Some of these projects with hard to locate parts you sorta get one shot at it and risk screwing it up worse..Incidentally the Classic Industries include a caveat they are not an exact match for the orginals on a Barracuda,but gotta say they look pretty darn nice anyway.
      • Dave NEO
        854
        164
        Jan 6, 2017
        midwest
        Local Time:
        8:57 AM
        well FWIW -using some meguiars a281f009-3b28-43a7-ba94-a768b5156990_1.6e8973d5097e345c55ec3e3f1828d763.jpg and though it's for made for clear plastic, with a fair amount of effort it seems to be taking out all the crud and leaving a very clean glossy finish I will add some wax to. surprised. Must be layers and layers of dirt and wax on there...
        • Like Like x 1
        • RedFish
          RedFish Well-Known Member
          23,052
          2002
          Sep 5, 2007
          Local Time:
          9:57 AM
          900 dollars for a dart part that isn't correct for b'cuda , then the chromed plastic trim pieces sold separately. That's a lot of incentive to make the correct originals look new.
          They should match the doors. Below the trim is a lower gloss like the vinyl. Above the trim a medium high gloss like the painted section of the door. OK they match the door painted metal again at the bottom but I wouldn't be highly concerned with the finish down there. Very little of it shows. I don't know that they used 2 different paints though. The texture or lack of would create 2 different finishes to the eye.
          I found a way to use the stainless trim piece form a door on the rear panels. One piece from either door cut in half is enough length to do both rear panels. The OEM plastic never exactly matched the stainless anyway.
          A lot of labor in modifying this piece of stainless. Not for everyone I'm sure.
        • Dave NEO
          854
          164
          Jan 6, 2017
          midwest
          Local Time:
          8:57 AM
          buffing up pretty good = may be I 'll get some pics
