Salter Racing Engines, 383 502 Hp & Tq
Not bad, 408 numbers with what a lot consider a throw away engine :)
Thanks. Mr. Salter proved what I have always said, “Lift that valve up as much as possible if the head can support it.” That head can support the .600+ lift and power numbers paid off.
Killer mild street build. That guy has an awesome reputation. Wonder what it would make with a hotter ignition system.
That and a ported RPM intake, it wasn't a fair comparison for the RPM going up against a ported torquer.
The RPM and Holley street Dominator are the absolute best for the low deck, OOTB and in ported form.
I'm not convinced till I see an apples to apples test on those 2 manifolds. Ported rpm airfare will only flow 230 fish cfm and he didn't post any flow numbers for the worker and the heads.
So it may or may not. Show me.
I
Trickflows single plane is a good manifold as well
Admittedly, I did skip ahead several times while watching, but my takeaway was the manifold comparo was the reworked original Torker vs an ootb RPM.
Was there discussion/video of porting on the RPM and I just missed it?
Snapshot of the end…….
At the top of the sheet there’s mention of swapping vr1 20/50 for Mobil 1 5/40
It would be nice to see the best sheet with the RPM, to see how the numbers compare in the area of the curve below peak TQ.
Mr. Salter proved what a lot of us have always known. You need to work your tail off AND have a wheelbarrow of $$$ ( think TF heads on 383 here) to FORCE a 383 to make comparable power to a SBC mouse motor. J.Rob
I don't want to hi-jack this thread but...I should start my own. So with the power of the internet/forums....I will. J.Rob
Do so and looking forward to it.
I beg to differ. J.Rob
Please explain
What's the $/ci ratio between Chev vs Mope on this one? J.Rob
MoPar is always more. Nothing new here. Why even bring it up? For those wanting to do a MoPar engine, they will do it knowing it’s more expensive and don’t anyway. Why are you bringing a Chevy engine into this?
Chevy being the cheapest of all. We know this already.
“Force” this I don’t get.
So why do most 408's absolutely trounce this admittedly max effort 383? J.Rob
More cubes equal more power.
How do you see it otherwise?
I haven’t seen any 408’s run a cam as small as he did and at the compression ratio as well. Every 408 I have seen is almost always running a sizable camshaft.
The smallest cam I seen a dyno sheet for was running a hyd roller at 224 or 226 @.050. That’s a small cam for a big engine.
