WAYNE0
Has anyone mad there own engine mounts to put a bb in a sb k frame ? Yea i know schumacher has them but if i can make them y not.
Yes.Has anyone mad there own engine mounts to put a bb in a sb k frame ? Yea i know schumacher has them but if i can make them y not.
yes he is!Is Jim Lusk a member here?
Make Your Own DC-K Frame
His how too represents the Tube mount later K frame VS the older biscuit mount. UNLESS I missed something?Is Jim Lusk a member here?
www.forabodiesonly.com
i check this out they used a newer k frame mine is the pancake type mount 67 barracudaIs Jim Lusk a member here?
i just rebuilt the whole front suspensionThe 73 up k frame would likely be better for you. 67 had the odd idler arm.
It is fairly easy to put elephant ears on a B/RB, and if I ever live that long, that is what I plan to do, instead of side mounts. this is because, of course, the way the water pump housing mounts. Then use generic donut mounts down on the stub frames.
I put spool mounts on a biscuit k frame. I have NOS engine mounts. If ya started from scratch you may have more options. While OEM biscuit and spool mounts work fine they are bulky.
