sorry to sounds rude before, i dont doubt you. when the dyno place told me 1050 i asked at least 20 different people, friends and people from my facebook who constantly are racing and they all said no way. 1050 is way too big.
both carbs were brand new.
im not sure of the jet sizes. id have to take it apart.
the idle speed screw is one turn away from the engine stumbling to a stall as in turned out ? dono if that makes a difference.
idle mixtures are 1/2 turn out from fully wound in .
jets id have to open up and take a look.
850 diamond series quickfuel q
1050 race q quickfuel
Did I mention...
TIMING FIRST!!!
Good luck
I fail to see a need for 20 degrees initial timing, imagine that would make it difficult to restart when hot... I've run racecars at 36 degrees locked out, but typically the ignition isn't switched on until the engine is already rolling over... Problems here are a combination of timing and carb issues, 20 degrees initial is not a cure all
So the car ran fine before when first in i hadnt driven it much 34 total with the 850cfm quickfuel.
Took to a chassis dyno shop to get it tuned. Pretty reputable shop (lol) they said at WOT i i have 2.5" of bacuum so which i guess makes sense needs a bigger carb . They said go with a 1050cfm i realise at this stage this carb is massive for the cubes/cam setup . Everyone advised against but i gave the boys a chance to prove me wrong and put on a 1050.
The printout showed 330hp now up to 350hp 20 extra all the way up the curve.
Took it home and drove it . Sounded a lot crisper . Especially coming off the throttle while cruising . But a bit gutless. Checked the throttle and was only going half way. Fixed it up now and it went hard . I called the place and they said they were 99% that it was fine . (Very strange)
interesting, the 850 made 330 hp, and the 1050 with half throttle (approximately 525) made 350 hp
360/408 sbm
360-1indy heads unported
10.28 comp
Solid roller 245/245 612/612 108 102.75
34 total timing i think around 14 initial from memory
Was around 10" vacuum at idle 850 -900rpm
1050 quickfuel raceq
Using bcpr6ey-11 bgk plugs
Msd ignition .
Although i like to open up the throttle a bit. The car does see a lot of cruising rpm 1500-3000 and idle time.
Problem being after driving for 20-30minutes the engine wont idle rpm slowly drops down to 500rpm and then will stall at lights.
By this stage the plugs are fairly black.
Questions ? Comments ??
Just a note for the OP: A big carb versus cubes is going to be a lot touchier to get the mixture right across the idle and transition phases of the carb operation than a smaller one. In fact, with too big a carb, it may never be fully correct all across the low end RPM operations at light throttle and idle; the fineness of adjustment is just not there, and the transition operation in particular assumes a certain % of maximum flow versus RPM and throttle opening; you are undoubtedly operating below that % flow with the large 1050.
That is the compromise that you are making with the 1050 carb to gain that 20 HP on the dyno. One question you may want to ponder is if that 20 HP is of that much value in your use of the car and engine; sometimes, people get too caught up in every last HP on the dyno and lose sight of actual operation. Spending a lot of time idling and at lower RPM's points to a smaller carb.
Well actually, I did not think or imply anything like that.... but that never stops people from inferring what they want. The reality is that unlike EFI with an O2 sensor and feedback, any simpler carb's transition operation is factory calibrated along some sort of flow and vacuum curves; you can vary around that curve but not change the curve in the simpler carbs that get dealt with commonly here. IF you are dealing with more tunable carbs like Weber DCOE's, THEN you can actually monkey around with the transition curves by changing the emulsion tubes as well as the idle air jets and idle fuel jets. Those variable parts just don't exist in these simpler 4 BBL carbs. (If you have never done DCOE tunes, then it may be hard to appreciate this point.)If all you do is jets and idle mixture screws, as this statement implies, then you are WAY off and missing a huge opportunity to get a carb right on an engine.
Would you prefer factory design' for the transition characteristic? In a carb like a Holley, it is fixed in the metering block. That is one reason to have different metering blocks for different size carbs in the same series. Not sure what the problem is here.Yep, "Factory Calibration", that reinforced my statement.
6 is sort of cold, comparable to a 9-10 champion plug.
In NGK`s a 5 is hotter than a 10.............
