nm9stheham
Just FWIW.... here is a diagram of the oil flow from the LA SBM oil system up to the rocker shafts. It shows passage diameters in inches and flow areas in square inches. There is data here for the stock setup and also for the PRW PQx aluminum rocker setup (which is what I was working on at the time.)
Besides the 'oil flow interrupter' in the cam holes, the next most significant restriction is where the oil flows through the head pedestal into the interior of the rocker shaft. So that hole size is critical to some degree. It is smaller in the PRW shafts and that makes sense; they told me it was so to control oil flow rates.
The flow out of the interior of the shaft for the stock system will vary with stamped versus adjustable rockers; the adjustable rockers will have a smaller outflow area if the rockers are properly tight to the shaft. So the shaft may be more prone to filling up with the adjustables.
(Hope you can read the diagram...)
