shopping frustrations!
cuda65vpt
cuda65vpt
colorado springs area
Trying to find a complete rebuild kit for the front suspension of my stock V8 1966 Barracuda. Can any of you fine folk point me in the right direction?
The immediate problem is that my left front tire has developed a leaning problem, the bottom is way out and wearing the inside of the tire. Is that a control arm bushing problem or ball joint? I figure it would make sense to do a complete rebuild while at it. Does that make any sense or should I just fix whatever is the problem?
TIA Vern
It likely needs a rebuild, but there are other things that can cause this including loose alignment cams. I recently installed Raybestos bushings and ball joints in a 69 B-body front end. They seemed to be decent quality, but the upper bushings do not have the full sleeve that the originals had (I'm not sure if any replacements have them). Raybestos is available from Bill Rolik Enterprises and JC Whitney. I may look around more the next time I build some control arms. Moog has been good, but is apparently outsourcing to Asia now.
PST is a sponsor of this website and even has their own area to help out our members. Take a look...
PST forum
Do you want a list, with the napa part #'s? I think I have it saved somewhere.
Did not visit my friend at Napa yet, I could not sleep last night so I went to http://www.napaonline.com/ and came up with a parts list.
....the guy I deal with charges me roughly 63% of these prices.
Pretty sure that the parts that begin with ncp are from moog.
66 cuda
upper ball joint mrc10164 23.49x2 or ncp2601044 68.49x2
lower left ball joint, disc brakes ncp2601103 87.99
lower rite ball joint, disc brakes ncp2601104 87.99
lower left ball joint, drum brakes ncp2601058 129.00
lower rite ball joint, drum brakes ncp2601059 129.00
offset upper control arm bushings (no price)
lower control arm bushings, ncp2673193 7.29x2
upper control arm bumpers, ncp2654005 7.29x2
lower control arm bumpers, ncp2654013 8.29x2
strut rod bushing, ncp2748999 5.29x2
inner tie rod ends, mrces319l 31.49x2 or ncp2692119 57.99x2
outer tie rod ends, mrces319r 31.49x2 or ncp2692120 57.99x2
tie rod adjusting sleeve, ncp2691102 21.49x2
idler arm, ncp2683367 59.49
piman arm, rpc20112 129.00
