hotrod swinger
My question: where are the locations for ground straps? Do i connect the battery ground to the water pump?
Is there a bolt hole at the back of the engine to ground to the firewall?
You surely are not worried about "restore correct" with that paint scheme, are ya?
And we apply way more paint on parts then the factory did causing more ground problems.Those cars usually had little grounded to the body..
