dibbons
We have two very heavy steel gates at the entrance to our property in Mexico. They meet in the middle and each have a pair sturdy cast iron 4" wheels that ride along angle iron (angle iron is set in concrete along the bottom). Over the last 10-12 years the bottom portion of both gates began to rust away (the fabricator that just repaired the damage said the original construction used too thin a gauge of materials). Anyhow, Jose the fabricator who replaced about a two foot section along the bottom of both sections (the portions still in primer in the photos) I thought did a good job of repairing the rust damage and used a thicker caliber metal in the process. However (and I'm not surprised), the two sections no longer meet up perfectly in the center (more gap on the bottom-about an inch).
Examining things with a carpenters' level, I find the gates are hanging almost good and square (the bubble just off a tiny bit) so things are already pretty close to perfect (considering the size of the gates and the extent of the damage, I can't really complain). Nonetheless, we need to find a quick and easy solution to get things lined back up so the lock on the gates can be re-installed. Since Jose sent two of his workers to perform the final installation, he has personally not seen the gap yet. Before he swings by, I thought about asking for opinions from construction savvy forum members on where to go from here? Thank you.
