Mojack
Is there any rhyme or reason why some shafts had the "banana groove" with oil hole and some didn't? It's not a stamped hyd. rocker shaft, they have a larger single hole on the bottom of the shaft.
the banana grooves are original from mopar for the 273 adjustable rocker arms. without them , they gall the shaft and rocker arm. hyd rockers have only a hole , because, the rocker doesn't sit tight on shaft, also has a trough built into it. other shaft, must be from other vendor??Is there any rhyme or reason why some shafts had the "banana groove" with oil hole and some didn't? It's not a stamped hyd. rocker shaft, they have a larger single hole on the bottom of the shaft.
