So I got this alternator...
adamsredlines
'69 Dart
Talala, OK
I have an alternator...pretty sure it was from either my Ramcharger or Duster....but its possibly from my buddies 86 C10.
Suggestions on how to verify?
Its got a 2-rib v-belt pulley.
Has a tag that says Ultima 01-0153 and 83277810.
Another tag 43 08 274 51
201 remanuractured 531
Just found that....they have it listed for the Ramcharger, not the Duster.
What would make it compatible with one and not the other? Both LA 318 motors.
Any reason it shouldnt work on my Dart?
Im trying to set up the accessory drive.
It will bolt right on to your dart. If you don't have A/C the dual groove pulley isn't ideal as it won't line up perfectly, but you can get by with it.
If you still have the 69 style VR you'll have to ground one or other of the field terminals, then hook up as per the old one.
No AC, I am going to be using March pullies for a serpentine belt (water pump, alternator, crank).
Are the 2-groove and single groove the same except for the pulley?
