MyD750
'71 Duster 340 TX9
As I'm between med issues/treatments/tests, I've been able to quickly slide in and do a bit more prep work in tear down of the Duster. I frequently take deep breaths and remind myself I probably did some of the same lame things when I was younger, that were done to the Duster. In getting things loosened on the exhaust, I've found 3 different types of bolts holding the factory exhaust manifold on. This seems to be a theme as I've found a mix of screws, nuts, bolts etc while disassembling. Hoping to get a lot more done in the next week and a half. Hopefully get the motor pulled and off to the machine shop. Not doing a whole lot to the motor, still have to see what's what inside. IF it's in pretty good, stock shape I'll probably just warm things up a bit inside with a CompCams Magnum stick (21-214-4) kit. Still contemplating headers, but not too hard. Cost to benefit just doesn't fit, and I'm not likely to do anything on the strip. I could always be convinced though...
Here's a pic of bolt that busted off. It was so weak that I thought it was loosening (properly) then it snapped. Oh snap! And that Fram filter? Must be welded on. More to follow, especially on the motor pull. Take care, be safe.
