Solid mounts
63SplitWindow
Montgomery County PA
It seems Shumacher may be out of business....number I have is disconnected. Anyway, I'm looking to replace my stock spool type rubber mounts with solid mounts. Anybody know where to get them?
Thanks,
Bill
@63SplitWindow, Schumacher Creative Services was sold to Motech Performance in November last year.
Suggest you contact Motech for product info:
Motech Performance
41715 Elm Street, Suite 301
Murietta, CA 92562
tel 951-813-3550
MOTECH Performance
The folks at Motech are good people!
I went from the Shumacher poly-loc mounts to the solid mounts because the driver side mount stretched apart. Solids haven't been a problem and the vibration was no worse
Um, those suggestions are for biscuit mounts- the OP said he has spool mounts?
Check with Prothane
Prothane Motor Mount Kit - Black : 4-504BL (pitstopusa.com)
Prothane 4-504 Chrysler/Dodge/Plymouth Car Motor Mounts | eBay
Not aware of any steel inserts.
The solid biscuit mounts can only be used if you change to the earlier K member and motor mount brackets.
You are correct Professor.....I have the spool mounts on my K member. I just ordered the prothane mounts. Let's see how they work. I'm hoping these will allow me to raise the engine about 3/4" from where it sits currently. I need that clearance to install new TTI headers. According to TTI, I need a minimum or 5 1/4" from the center of the crankshaft bolt to the top to the K member. I'm more than 1/2" low now
