I am looking at upgrading my engine for a little more power over a broader powerband. I am having a hard time time finding information on roller cams for 360 builds. It appears that most people just go with a hydraulic cam, but after entering information into camquest it looks like a solid roller would make 50 hp more than a hydraulic. I was told how a solid cam will act like it has 10° less duration than a hydraulic cam. What about a solid roller? With the 65cc heads, my new compression ratio is 10.39:1 with a .045" quench. I have 1.5 adjustable rocker arms. I have 3.23 gears with 245/45/17 tires (25.7", should be turning 2300-2400 rpm at 55), 2500 stall, low gear set 904, 3300 lbs Dart, RPM Airgap Intake, and 750 Double Pumper with proform main body. I currently have 2.02 J heads and the MP Performance solid cam 284/284, 241/241 @ .050, .528 Lift, .028/.032 Lash. With 3.91's and 26" QT Pros,the car ran a best of 7.79'. I am looking at these 4 cams. I don't really plan on going to the track regularly. I want a hot street car not a race car. The cams that I am looking at are below. The cams appear to be very similar to me besides the rpm range, but I figure that is just a generalization that they put on each cam. The Comp recommend spring 914-16 that is a 367 lb/in, and the Lunati recommend spring is a 550 lb/in spring. It seems like a big difference. I am thinking of using MRL Performance's Lifters unless swayed otherwise. I am pretty sure these cams will idle fairly smooth, but I am a little concerned if I will be able to run 91 octane without pinging. Using a dynamic compression calculator for the cams, I get a range from 8.66:1 to 8.27:1.
Any suggestions?
Comp XR268R
268/274 Duration
230/236 @ .050
.552/.056 Lift
110° Lobe Seperation
106° Intake Centerline
.016/.018 Lash
2000-6000 RPM
Comp XR274R
274/280 Duration
236/242 @ .050
.564/.0570 Lift
.016/.018 Lash
2200-6300 RPM
Lunati 40200730
261/267 Duration
231/237 @ .050
.555/.0566 Lift
.016/.016 Lash
2400-6400 RPM
Lunati 40200731
267/273 Duration
237/243 @ .050
.566/.0578 Lift
.016/.016 Lash
2500-6600 RPM
Any suggestions?
Comp XR268R
268/274 Duration
230/236 @ .050
.552/.056 Lift
.016/.018 Lash
2000-6000 RPM
Comp XR274R
274/280 Duration
236/242 @ .050
.564/.0570 Lift
.016/.018 Lash
2200-6300 RPM
Lunati 40200730
261/267 Duration
231/237 @ .050
.555/.0566 Lift
.016/.016 Lash
2400-6400 RPM
Lunati 40200731
267/273 Duration
237/243 @ .050
.566/.0578 Lift
.016/.016 Lash
2500-6600 RPM
