Delta One
Δ1
So I am having an issue concerning finding a speedometer that fits. My '74 Duster's stock speedometer cable is a one piece cable with a small nut that connects o the transmission, and a plastic clip connection on the instrument cluster side. I now have a 1986 Diplomat 318 in the Duster, and the cable has two nut style connectors, one small on the cluster side, large on the tranny side.
My question is this: Is there a way to remove the speedo connection point plate from the tranny? It looks like it is retained by a single bolt. Can I swap it out for a small pattern connector?
I have the stock cable and the '86 cable, but neither fit. The stock has a plastic connector and a small nut. The '86 cable has two metal nut connectors, one small and one large. I need plastic and small.
Any help is appreciated.
- Δ1
- Δ1
