Speedo Cable for push button or cable shift 904
amusingarts
Texas
Hi Guys,
I'm looking for a source for a new speedo cable. The trans is a TF6/904 in a 65 Valiant with a 273.
The cable has the gear attached to the cable on the trans end, haven't been able to locate one like it. Any ideas?
Picture attached
Got a pair of speedo cables for the 65/earlier transmissions - one is definitely used the while the other appears to be NOS. I do have gears as well.
FWIW the same cables are used with the 65-earlier slant/V8 904 and the 833. I can take some pics if interested
Got a pair of speedo cables for the 65/earlier transmissions - one is definitely used the while the other appears to be NOS. I do gave gears as well.
I'd be very interested. The one I'm replacing had a kink in the outer housing that leaked and finally broke it in half.
I currently have a white gear, but I upgraded to 14" tires so my speedo reading is faster than I'm actually going, but I don't know what would be the right gear for the rim size/?
I’ll get some pics when I get home and take a look in my 65 TSM. It should give Gear sizes based on tire size
