I am working with a mostly stock 318 in a 1970 Dart - add LD4B, Edelbrock 600cfm, Edelbrock performer cam, Mopar electronic ignition.
Engine was rebuilt 15,000 miles ago. The engine runs just fine once it starts.
When cold, tap the gas to set the choke, engine starts right up, no issues.
When driving around and making stops, if the car sits from 5 to 30 minutes, the starter grinds and grinds and grinds, then the engine starts up, runs rough for a bit, then runs fine.
Unlike my other Darts, this one still has an original type starter. Once the engine starts the ammeter pegs at charge and relatively quickly comes down to just a bit above neutral and stays there while running. With the engine running after the ammeter comes down, the battery reads at 14.5 volts, turn it off and it reads 13.5 volts.
Suggestions for causes for the hot start issues???
